| Hey Guys I want to swap my AT to a manual transmission. So far all i have manual transmission, the clutch and the flywheel from a twinturbo z32. I have all shifter parts except the leather cover. Also 1992 Manual transmission Twinturbo starter. Will my current stock automatic driveshaft work? Can i use NA master cylinder work? How about the NA pedals? i heard people prefer these over the TT versions for the swap... why? So far im looking for master cylinder NA? TT? slave cylinder NA? TT? pedals Na? tt? driveshaft?! ecu? rear main seal What else do i need? I dont think the auto ecu is compatible... Which EBC and ECU upgrade do you recommend for stock injectors and and stock turbos?
